Transferring settings in Rhino 8
I’ve seen a lot of posts about this topic, so I’m creating this post as the definitive guide.
Transferring settings in Rhino 8 can be done quite easily on and/or to either platform.
On the source computer
1. Close Rhino
Close every Rhino you have open.
2. Find your Settings Folder
Windows
%APPDATA%\McNeel\Rhinoceros\8.0\settings
Mac
~/Library/Application Support/McNeel/Rhinoceros/8.0/settings
3. Copy the settings folder
Make a copy of this settings folder that you want to transfer to the target PC/Mac
On the target computer
1. Close Rhino
Windows
Mac
3. Rename the settings folder
This ensures we have a backup in case anything goes wrong.
Something like settings_bak is fine.
4. Paste the source settings folder
Take the source settings folder (it should be a folder called settings full of XMLs) and paste it in this folder:
Windows
Mac
5. Open Rhino
Everything should be loaded by Rhino.
Known issues
Aliases
Aliases are named differently on Windows and Mac
On windows they are under a setting called AliasList, on Mac they are under a setting called Aliases if you want to move settings to a different OS changing the name OR copy pasting that setting group and renaming it so both exist will solve aliases not transferring between mac/win.
Plug-ins
Plug-ins can be done by following the above procedure, in that case copy the Plug-ins folder instead of the settings folder.
What about OptionsImport/OptionsExport?
These commands are no longer the best way to move settings between installs. If this works for your use case, continue to use it as needed.
The new user will use this option, while the old user will use the second method :grin:.
In the V8 macOS settings folder, there is no “Aliases” file that could be re-named for the above procedure.
This gets geeky unfortunately, but it’s the Aliases / AliasList key in the xml.
Mac:
Win:
Cheers, so I tell people to edit the XML, which they’ll find in the “settings” folder they receive from me.
Up to you, but why not edit that xml for win users, or export your aliases separately, that seems a little more elegant for now.
Emailing them two files is also an option, yes.
You can include both sections inside the same xml too.
Hello Callum.
Is it possible to change the settings folder location? I would love to point it to my Dropbox so I can have my Rhino settings sincronized between my desktop and my laptop.
Thank you!
It would certainly be fun for me to try! I wonder what would fail. But this setting does not exist currently.
