In Rhino 7, you added the ability to be able to move an object “vertically” in the direction of another object’s surface normals with the Move (Normal) command line option.
For Rhino 8, could you add the ability to move an object along the U/V directions of a surface/polysyrface? Being able to move this gem along the surface while it kept the same relationship to the normals would be game changing for many applications.
Move an object along a U isocurve or V isocurve of a surface?
OR
Move an object along a surface and have it remain in the same orientation relative to the surface normal. In other words the object being moved would rotate as the surface normal rotates?
thanks for getting back to me so quickly, @davidcockey.
Ideally, I’d like to be able to move an object along a surface and have it remain in the same orientation relative to the surface.
In this example, I’ve used Orient On Surface to place gems on one side of a compound-curved polysurface. The last gem (selected) doesn’t fit my desired pattern very well.
In Rhino 7, I have to delete the one gem and repeat the Orient On Surface command.
I want to move the gem so that if fits snugly into the pattern created by the other gems.
At the same time, I need to keep the gem oriented so that the big flat facet on top remains perpendicular to the surface’s normals, and also maintain the gem’s relative height over the surface (in the direction of the surface normals).
Hi Mike… I know it’s been a while since you’ve posted this issue. I’m wishing for the same! Have you had any luck finding a solution? Thanks in advance!
Hi @David_Alan,
No, I haven’t had any luck finding an alternative in Rhino. The best I’ve been able to do for this problem is to use Flow Along Surface (which can distort the spacing between gems) or for small moves on a gently curved surface using Gumball in “Align to Viewport” mode while looking straight at a gem.
Unfortunately, I have not.
This is a real shortcoming of Rhino. I will continue on my search to find a way to make this work. If I come up with a solution, I’ll be sure to post it here.
