I understand this is probably not for everyone, so it could be an option.
It would be great to keep the layer name column visible when you slide laterally to edit the increasing number of properties. I know that if you hover over the line it hints the name, but it takes a bit and if you selecting several layers, you see it one by one and it just is a bit slow.
Also I know that you can select on the column and them slide over to the property.
But pinning the layer name column, would also help to check properties against the name. So if I want to know what are the layers have printing width of .35 I can look at the two columns at the same time, and have better checks.
Any ideas?
Thanks, N
