Layer readout at the bottom
hovering over it should show the whole path of the layer. Most of mine are too long to fit in the box and it just chops off everything past a certain point.
the box in the properties window only shows the name of the layer, not the path unless you click
would be nice to be able to see the route down the layer tree at a glance
Hi Ryan,
Interesting idea… Can you try using the right click menu over the lower right to enable the current layer name to be displayed all the time? This might do what you’re after without changing the layer pop up behavior.
Think I need a wider screen :smile:
Perfect. As usual I didn’t even know that menu existed. Thanks Brian.
