Toolbar tooltips
Tooltips isn’t working for me on windows. Is it broken?
Rhino 8 SR5 2024-3-5 (Rhino 8, 8.5.24065.13001, Git hash:master @ cfc026bc6a854ff160d2b4978aef67a7cbfcb5de)
License type: Commercial, build 2024-03-05
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24065.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24065.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24065.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24065.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.5.24065.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24065.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24065.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24065.13001
Seem to be working here, I have the same card, driver is from 18 January, so just a bit older…
I tried turning Rhino.Options.CursorToolTip.EnableCursorTooltips to False (I figured I’d turn it to false and back to true and see if that fixed it.) When I switched it to false, the tooltips worked! So I restarted Rhino, and it was set back to True and tooltips were not working. So I switched it back to false, and they still didn’t work. So I tried it back and forth but was not able to get them to come back.
Here’s how I can get tooltips to work: I open something else (like a browser window) and then return to Rhino.
Hmm, OK, I never messed with the advanced options…
I have the same problem. I thought they were fixing something
My first (and hopefully last) time!
I’m feeling like I just have to wait for 8.6 and see what’s fixed in that version.
Hi Peter - I can’t tell if you enabled these in Options > ModelingAids or only in Advanced…?
I guess cursor tooltips isn’t really what I’m having issues with - it was just the only thing I could find that seemed like maybe it applied.
My issue is with tooltips when I hover over toolbar buttons. They never work, unless I go to another window and then back to Rhino, then they work during that session.
Got it. There have been some fixes in this area in recent days/weeks but I do not right now see anything that looks directly related to this.
Save your settings. Then do Reset. Factory Reset Problem solved.
Yeah, I should probably do that.
Mine worked fine until just now when I updated to Rhino 8.6.24…
Rhino 8 SR6 2024-3-26 (Rhino 8, 8.6.24086.11001, Git hash:master @ 8e3b686f596bb6443e56e6dbecf0f54f4888713a)
License type: Commercial, build 2024-03-26
Windows 11 (10.0.22635 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.17
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 3-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.86
Secondary graphics devices.
NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 3-12-2024 (M-D-Y).
- Secondary monitor attached to adapter port #0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 3-12-2024
Driver Version: 31.0.15.5186
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\CodeListener (8c4235b6-64bc-4508-9166-bef8aa151085)\0.1.7.0\Rhino 5.0\x64\CodeListener.rhp “CodeListener” 0.1.7.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\CLines_Pascal\CLines.rhp “CLines” 0.1.8023.28213
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Cephalopod\0.0.2.0\Cephalopod.rhp “Cephalopod” 0.0.1.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\rhinopbrmaterial\1.1.4+v6.16\RhinoPbrMaterial.rhp “RhinoPbrMaterial” 1.1.2.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
Me too sometimes have no visible Tooltips. Close and reopen Rhino and Tooltips could be there, just ‘could’. Solved clicking Help from the menu bar, Rhino open the Browser, I close it and tootips get visible again
System Info.txt (2.1 KB)
I tested 8.10 and it still doesn’t show up
I have same problem, it is a bug obviously. tooltip rh8.mp4 - Google Drive
here there is a video showing that. With rhino opened i tried giving the focus to something( a browser, a document…) and going back to rhino tooltips work. i used sr11 and sr12
