Tooltip does not work correctly
I noticed that the helpul Tooltips only works once the Rhino 8 Window has been reduced in size and enlarged again using Win 11.
Robert
hi @smartrobert pls run _SystemInfo in Rhino and post back the results. It would be also helpful if you could share a short video capture of your screen. I’ve seen more reports of tooltips not working, but so far I could not reproduce that on my end.
Same in here, no tooltips.
Then I wanted to record the effect, and before starting the recorder the tooltips are magically there.
Observation:
Start Rhino, and don’t place the mouse over the splash screen.
Wait until the splash screen vanished.
Rhino doesn’t have the focus - so no tooltip.
Not sure, but perhaps that is part of the reason?
I don’t see that here either
I think this is the same issue as mine:
Hi @Gijs de Zwart,
in Rhino 8 you´ve to open an existing Project, so you´ll see the Probelm with the Tooltips.
SystemInfo:
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05001, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Kommerziell, Build 2024-04-10
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [88% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 5-28-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 3-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.76
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-1-2024
Driver Version: 31.0.15.5176
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.0.0.0\KeyShot9RhinoPlugin\Rhino 5.0\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “LeerlaufProzessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24101.5001
My experience is that clicking on any other window and then going back to Rhino will make the issue go away (which makes it impossible to do a screen record, but maybe I’ll take a vid with my phone). Here is my system info, in case that helps narrow something down:
Rhino 8 SR7 2024-4-10 (Rhino 8, 8.7.24101.10001, Git hash:master @ 2b50f55c58918e10b4e2d13323128fce6021b72c)
License type: Commercial, build 2024-04-10
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Total Video Memory: 12 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24101.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.7.24101.10001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24101.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24101.10001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.7.24101.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24101.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24101.10001
Thanks all, I could now reproduce it reliably:
RH-81647 Tooltips don’t show up after starting Rhino
404 fixed
The tooltips still don’t work properly. They can be launched by pressing the Windows key, but that’s not the way to use Rhino.
Btw, I don’t have this problem anymore.
