Rhino 8 UI glitch
Hello! New user here I am trying to get into Rhino but having difficulties with the UI glitch. My laptop (1920x1080p) is connected to an external monitor (2560x1440p) UI has some strecthed text and disappearing icons that makes it unusable. I am on Windows 11 and tried re-installing drivers and also software but those didnt helped. Any solution?
Thanks in advance
Sami
Rhino 8 SR25 2025-10-21 (Rhino 8, 8.25.25294.11001, Git hash:master @ dbd34d09714449d20e5a207d4433f62e2963f282)
License type: Evaluation, build 2025-10-21
License details: Cloud Zoo
Expires on: 2026-01-21
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 31GB)
.NET 8.0.14
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 9-16-2025 (M-D-Y).
Integrated accelerated graphics device with 5 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 10-9-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.57
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-9-2025
Driver Version: 32.0.15.8157
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.25.25294.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.25.25294.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.25.25294.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.25.25294.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.25.25294.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.25.25294.11001
Do you see the same if you don’t connect your external monitor?
What region settings are you using?
Can you try a repair of Rhino to see if that resolves this?
I connected my laptop to another monitor which has 1920x1200 resolution via directly hdmi port and this seems ok no problems so far.
But its weird that the problem occurs connecting through usb type C hub that has hdmi 2560x1440 resolution output. No other program do this kind of visual problems its only Rhino.
I guess its something about resolution scaling.
