Rhino 8 Service Release 24 for Windows and Mac (8.24.25281) is now available
Rhino will automatically update, unless updates are disabled.
Download the latest service release now…
Bugs Fixed:
- Annotation: DimLinear: DimAligned / Dim shifts after changing properties (RH-89220)
- Annotation: Hatch: Overwriting existing pattern does not update in viewports (RH-88326)
- BlendSrf:
- Display:
- ExtendSrf: ExtendSrf_old behaves differently (RH-89006)
- Grasshopper:
- History: History replay of dimensions when extrusion turns into brep (RH-89215)
- InsertEdge: Fails to update Radiate symmetry (RH-82094)
- Join: Extreme slowness caused by unnecessary brep duplications when fixing bad objects (RH-89254)
- Linetype: Importing line weights makes Rhino crash (RH-88982)
- Revolve: Deformable=Yes creates rotated output (RH-88979)
- Ribbon: Makes bad geometry (RH-89031)
- ScriptEditor: Code close does not save to existing storage (RH-89314)
- Selection: Weird left-click behavior on Mac (previously clicked items remain selected) (RH-89120)
- Undo: Curve points are deselected after undoing a move (RH-88900)
Crashes Fixed:
- Grasshopper: Offset Loose component crashes Rhino when connecting Invalid curve (RH-88858)
- RDKCrash: Content Instance Browser dialog crashes (RH-88897)
Enhancements:
- HighlightObjectLayers: Should open Layers panel (RH-89079)
- LayerStateManager: User confused on ability to exchange layer states between files (RH-89284)
Regressions Fixed:
- BlendSrf: Blendsrf failing in v8 and v9, but works in v7 (RH-89796)
- ScriptEditor:
- SelBoundary: Takes too long to finish (RH-89029)
- UVEditor: Added back ability of copying UV meshes to clipboard (RH-83978)
SDK Enhancement:
- SDK: RhinoCommon:
UI Change:
- Grasshopper: SubD turns null when opened in Rhino 7 (RH-88081)
Mac-Only Changes
Bugs Fixed:
- Annotation: Hatch: Gradient hatch handle not visible (RH-87649)
- PackageManager: PackageManager install dialog not showing buttons on Mac (RH-89655)
- Properties: Object's Layer Color is Confused (RH-89712)
Windows-Only Changes
Bugs Fixed:
- Rhino Inside: Rhino running headless displays popup about missing fonts (RH-89162)
