Hi -
An error report pops up as soon as it is opened and it closes automatically.
Thanks for sending in the crash report.
Does Rhino start in safe mode?
Is the system entering safe mode?no.It’s in normal mode.Isn’t it possible to let Rhino run in safe mode alone? How to operate it?
Great problem solved. Thank you!!
Hi -
Well… no, it isn’t.
That is only a step to troubleshoot the issue and it shows that the problem is either with the drivers of your GPU(s) or with plug-ins. From your crash report, I see that you are running at least two 3rd party plug-ins: Sunflower (9.9.0.0) and V-Ray for Rhino (5.10.06 ( Jul 27 2021 )).
I’d start by disabling or uninstalling those to see if that makes it possible for you to start Rhino the normal way.
Yes, it has been solved, and after the plugin is deactivated, the software can start normally,thank you!
which plug in was the problem, were you able to determine?
