Rhino 8 OpenGL not recognize Nvidia card?
Hello, I have the GTX 4060Ti on my computer but in Rhino 8 it doesnt recognize it and the anti-aliasing seems not working. Any suggestion ? Thanks !
Hi Vu, please run SystemInfo in your Rhino command line and post the results.
If you go to Device Manager in windows are there any warnings on the graphics devices?
A clean install of the video driver is the next step.
https://www.nvidia.com/en-us/geforce/forums/geforce-graphics-cards/5/139267/clean-installation-of-nvidia-graphics-drivers/
Thanks. maybe this is the problem:
I am using a monitor has only Display Port, no HDMI.
Secondary graphics devices.
NVIDIA GeForce RTX 4060 Ti (NVidia) Memory: 8GB, Driver date: 8-14-2024 (M-D-Y).
- There are no monitors attached to this device!
ATTENTION:
Desktop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
There is only one monitor detected, but it’s connected to the slower, integrated graphics video port.
  • Recommended: Unplug the monitor and plug it into one of the video ports on this device:
    [NVIDIA GeForce RTX 4060 Ti]
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 32.0.101.5542
Driver Date: 6-8-2024
Driver Version: 32.0.101.5542
Z-Buffer depth: 24 bits
Total Video Memory: 2097148 KB
If you have your DisplayPort cable connected to your motherboard, can you move that cable out of the motherboard and into the 4060 Ti?
Normally there is a mixed config on the back of modern GPUs of DisplayPort and normally at least a single HDMI.
Most video cards have a displayport? There are also surely HDMI to DP “adapters”
there are 2 displayport slots and 1 HDMI slots. I tried connect to HDMI and Displayport (with the good cable from UGreen). Nothing happens. May I try to reinstall the driver.
That’s probably a good start. I cannot see what driver you have.
But afterwards, you should do a shutdown, and then restart with the cable attached to the graphics card.
It may take a few moments for the motherboard to catch up on restart, so leave it a minute to make sure that it recognises the GPU is now the throughput.
Thanks. After doing “cleaning install”, it works.
Hello, sorry for one more question:
Hello all, my current setup is
12th Gen Intel(R) Core™ i5-12400
Gigabyte b760m ds3h ax ddr4
Adata 32 Gb RAM (16 x 2)
Gigabyte RTX 4060 Ti
I am thinking about buy more 2 16Gb RAM, to make my PC has 64Gb. Is that ok or not necessary? My current setup is enough for Rhino & Grasshopper?
32 GB is normally fine.
I think you could upgrade to have 4 RAM sticks. However for the purposes of best performance it is usually better to maintain a 2-channel setup with 2Ă—32 GB than 4Ă—16 GB.
In addition, I think RAM sticks of good quality are normally paired.
