closed curve with simple lines and curves fails to offset with Loose=Yes option in Rhino 8 and Rhino 7.
Offset curve - Loose=yes option R8 and R7.3dm (72.3 KB)
Hi Teo - that is, it seems to me at least, a lot to ask - my guess is Loose does not do anything very complex, it moves control points. It does not try to figure out extensions for example, that make the hard outside corners in Offset, which are not really offsets at all.
Yes, I’ve noticed this too. I opened an issue here.
Thank you Joshua, I look forward to it.
Noticed that youtrack/issue is not pubblic.
Teo
Sorry about that. It should be visible now.
I have found Rhino 8 curve offsets to be all over the place with self intersecting loops in corners etc. I am also finding solid bodies from Rhino7 coming into Rhino 8 and showing as open when the section view is on. Pretty buggy at the moment.
Please send me examples so I can fix this
Sure, how do I send them to you?
You can post the files in this thread, direct message me here with the file, or you can upload them to support for me here. That link also has my email and you can email me directly.
A good step forward. Thank you!
