Add the Loose option to it?
Hi Jonathan -
Added to the list as RH-63417: Offset: Add Loose option to OffsetMultiple
Thanks Wim. I tried to macro it but couldn’t - not done a macro in a while and it’s tough to get back into remembering what the logic is.
Also - is it known why a closed curve offset loose could result in open curve segments?
two_loose_offsets.3dm (43.4 KB)
I offset the inner curve by 1mm loose twice. offset loose by 2mm once is a closed result however. I had some filleted curves that I offset loose so I could make cleaner lofts with them. But now offsetting the curves has lost that G1 continuity and might become messier during edge filleting.
