Micha
November 16, 2023, 6:39pm
1
Rhino 7
Rhino 8 - material option missing
wim
(Wim Dekeyser)
November 17, 2023, 2:51pm
2
Thanks for reporting, Micha!
→ RH-78405 CurvePiping: Material tab
November 17, 2023, 3:20pm
3
Hi @Micha , I wanted to ask you:
the curve in Rhino8 that you used to do the Piping,
have you set the curve type as Dashed/Hidden similar?
Micha
November 17, 2023, 3:34pm
4
Yes, but also for standard linetype I get no material tab.
0904
November 17, 2023, 10:25pm
5
ok thanks, I was asking for confirmation because in my case even by changing the type of line the curve is always displayed continuously, while the tube is displayed correctly by changing its shape…
0904
November 17, 2023, 11:16pm
7
as you can see from the photo the line remains continuous.
Gijs
(Gijs de Zwart)
November 17, 2023, 11:28pm
8
@micha , just to be sure, for now you should still be able to apply materials to the curve through the material editor.
@0904 pls run _SystemInfo in Rhino and post back the results.
November 19, 2023, 2:35pm
9
dreaded question: my computer is more than 10 years old (prehistoric PC)
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 4Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: ATI Mobility Radeon HD 4500 Series (AMD) Memory: 1GB, Driver date: 1-13-2015 (M-D-Y). OpenGL Ver: 3.3.11672 Compatibility Profile Context
> Accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Hi @Gijs ,
perhaps as already said in this post, even in this case it can be attributed to the PC being too old,
even if when trying the other versions at least this type of problem did not occur.
(That said, obviously my PC cannot be taken as a reliable control)
Gijs
(Gijs de Zwart)
November 19, 2023, 6:51pm
10
This explains a lot, and cannot be fixed by us.
