Rhino 7 Materials Panel is not displaying previews or options
Hey, somehow when I open a specific projects, sometimes the materials-panel doesn´t work properly, I cannot scroll, there are no previews and also no options to change something. Is there a way to reset this without deleting all my materials?
Due to confidential content I cannot share the project unfortunately :frowning:
Thanks for any ideas in advance :slight_smile:
As you can see when the panel is smaller, there is also no scroll bar.
Screenshot_4
What do you have set as your current render engine?
Please also post the results of the Rhino command _SystemInfo.
HI Nathan, I didn´t change anything on the render engine, so it is the defualt one I suppose.
Rhino 7 SR8 2021-7-15 (Rhino 7, 7.8.21196.05001, Git hash:master @ 45c1fd6dc85c7c1cce8c0bbe6f3e16481ae9abfa)
License type: Commercial, build 2021-07-15
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Primary display and OpenGL: NVIDIA Quadro T2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 9-13-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.08
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 5-5-2020 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-13-2021
Driver Version: 30.0.14.7208
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\import_SVG.rhp “Import_SVG” 7.8.21196.5001
This is the Pane:
Hi Sebastian -
I would start with updating to the current version.
Hi Wim, good hint, I will try that.
Note that if I open a new project or open another one this problem is not there. It is only on 2-3 projects.
Hi Sebastian -
In that case, in if updating to the current version doesn’t change anything, could you try to eliminate objects from one of those projects to see if you are left with specific objects that trigger this?
