Rhino 7 Thickening tab is disappeared under the properties tab
In Rhino 7, under the Properties panel/tab, there are several sub-tabs, such as Object, material, texture mapping, decal, thickening, etc; however, that thickening tab has disappeared, along with a few other tabs, I have attempted to get it back by changing the settings to default and even reinstalling Rhino, but my thickening tab is still not there, any thoughts?
Hi Justus -
Please run the Rhino SystemInfo command and copy-paste the result here.
Apart from that, what type of object do you have selected when you go to the Properties panel?
Hi Wim, thank you for your reply.
Here it is
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Commercial, build 2023-12-12
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 7-11-2023 (M-D-Y).
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 12GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\SimLab\Plugins\SimLab Rhino Integration\SimLabComposerIntegration.rhp “SimLab Composer Integration”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\import_GHS.rhp “General Hydrostatics (GHS) Import”
I just selected a simple surface, I mostly need the thickening tab show up again so I dont need to offset/extrude them to be polysurfaces unneccessarily
Hi Justus - Do these show up if Rhino Render is the current renderer? If not, please look in OPtions > Plugins page and make sure these plug-ins are present and enabled:
hi Pascal, the current render is indeed Rhino Render, and those two items are both checked in Options
and for visual reference
this is what my properties panel looks like in Rhino 7
this is what it looks like in rhino 8, where the thickening tab is present, along with a few additional tabs
Hi Justus - I would block - uncheck Enable - the Vray plug-in in Options > Plug-ins page, then close and re-open Rhino - any better?
unfortunately, disabling Vray plug-in still wouldnt doesnt seem to do the trick
