Hi all,
since updating to v8 (I think) i have this issue with the display of curves in the viewport:
If I zoom in (enough), the ‘artifact’ disappears:
anti-alias is at 4x, tesselation enabled
Thanks!
Hi, did you try to increase the line’s thickness in the display settings?
Also, have you checked if video drivers are updated?
If you set a different display mode like shaded, pen or technical, the artifacts are still there?
Ps run systeminfo, copy and paste there the resulting text.
@Terribel can you share (part) of that drawing that shows the issue? Does it consist of small line pieces?
and yes please:
Hi, thanks for your response!
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Educational, build 2024-10-08
License details: Cloud ZooWindows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0Computer platform: LAPTOP - Plugged in [89% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 3-22-2021 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce GTX 1650 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 7-30-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.81
> Integrated accelerated graphics device (shares primary device ports)
- Video pass-through to primary display deviceOpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU’s maximum)Anti-alias mode: 4x
Mip Map Filtering: Linear
Anisotropic Filtering Mode: HighVendor Name: NVIDIA Corporation
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-30-2024
Driver Version: 32.0.15.6081
Z-Buffer depth: 24 bits
Total Video Memory: 4 GBRhino plugins that do not ship with Rhino
C:\Users\IO\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PetersTools\3.2.5\PetersTools.rhp “PetersTools” 3.2.8821.23041
C:\Users\IO\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Clipper\0.3.3\ClipperPlugin.rhp “Clipper” 0.3.3.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”Rhino plugins that ship with Rhino
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\export_AI.rhp “Adobe Illustrator Export”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\QuadRemesh\QuadRemesh.rhp “QuadRemesh” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24282.7001
Drawing in attachment.
The ‘knots’ indeed appear in arreas where there are more points. But somehow this was less of an issue in Rhino 7…
Drawing.3dm (2.3 MB)
Hi All,
Still having the same issue with the latest V8.
Any suggestions?
