I have no idea what is causing this, and its repeatable.
I am using Rhino 8. I first thought that it could have been a problem caused by me using a lot of nested block instances, but even after exploding each block I still encounter the same issue. Weirdly it doesn’t happen when I try to make2d only one square, but when I try again with more at once the same problem occurs. There are also random weird missing lines.
There are no hidden or locked layers or objects in the file you posted, but there is no clipping plane in this scene.
I’ve added a clipping plane and wasn’t able to notice anything wrong with the Make2D output. You don’t say it in clear text, but I assume the problem on your end is the long red horizontal and vertical lines?
Please run the Rhino SystemInfo command and copy-paste the result here.
Hello, thank you for the prompt reply. My apologies… I exported that part of my file to post here and must have forgotten to include the clipping plane. Yes the long lines stretching to infinity is the issue I’m trying to resolve. I’ve just downloaded Rhino 7 on the same computer and exported the file as a Rhino 7 3dm, and I managed to successfully make2d with no issues. The problem seems to only occur on Rhino 8.
Anyhow, heres the systeminfo you’ve requested:
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13001, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Educational, build 2024-03-12
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4060 (NVidia) Memory: 8GB, Driver date: 7-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.67
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-12-2023
Driver Version: 31.0.15.3667
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
D:\Plug-ins\Commands.rhp "Commands" 8.5.24072.13001
D:\Plug-ins\rdk.rhp "Renderer Development Kit"
D:\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.5.24072.13001
D:\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.5.24072.13001
D:\Plug-ins\NamedSnapshots.rhp "Snapshots"
D:\Plug-ins\MeshCommands.rhp "MeshCommands" 8.5.24072.13001
D:\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.5.24072.13001
D:\Plug-ins\RhinoCode\RhinoCodePlugin.rhp "RhinoCodePlugin" 8.5.24072.13001
D:\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.5.24072.13001
D:\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
D:\Plug-ins\Displacement.rhp "Displacement"
D:\Plug-ins\SectionTools.rhp "SectionTools"
Please provide a 3dm file that you can reproduce the issue with. If that means that a larger file or proprietary geometry is needed, please upload that file from Rhino Accounts
