I am starting to have to deal with a lot of bugs that I don’t really know how others can test.
I’m running Rhino 8 on a 2019 iMac, which admittedly is starting to get a little sluggish, my normal use involves a 2015 Thunderbolt monitor as an extended display.
It began as noticing an issue with drafting: Dimensions don’t snap correctly when drafting in layout if my window is on the iMac desktop, so to draft I have to drag the window to the Thunderbolt Monitor, however, hatches don’t appear to work on the thunderbolt monitor, so I have to drag the window back to the iMac to hatch things.
A follow up issue is that in my workflow on the Mac, I do a lot of screenshotting model views and messaging them to colleagues to show progress. If I screenshot something in Rhino, then drag the screenshot to messages, Rhino crashes. I’ve since discovered that any drag-and-drop file move while Rhino has an active window on my desktop, will crash Rhino.
I find this odd, and it is starting to take up a lot of time. It also doesn’t happen with any other software on my computer.
I can only assume it is Graphics Card related…?
My system is as follows:
iMac, Retina 5K, 27-inch, 2019
3.6 GHz 8-Core Intel Core i9
Radeon Pro Vega 48 8 GB
72 GB 2667 MHz DDR4
Built-in Display: 27-inch (5120 × 2880)
Apple Thunderbolt Display
27-inch (2560 × 1440)
Thanks,
Nick
