Freeze when dragging and dropping a picture
Continuing the discussion from Rhino 8 for Mac is a massive regression in UI, UX and function:
Pls run _SystemInfo and post back the results. I could not replicate this behavior here.
I managed to capture the bug at least in a small scale. Please see attached screen recording and also the SystemInfo file.
Note: The lag time seems to vary depending on the size of the image being dragged.
_SystemInfo.txt (12.2 KB)
I just found out that this lag also happens if you drag the location folder (where you want to export your file) to the export window.
