I installed the Rhino 8 trial version on Windows 10 (Rhino 7 was working fine) but it keeps crashing once I try to open an existing file or draw a simple geometric shape like a circle.
I tried running Rhino on .net but the problem remains.
Hi David, Please open a new Rhino file and run the SystemInfo command and post the result. This is most likely due to your video card setup. Thanks
Thank you
I just did, here the results:
Rhino 8 SR9 2024-7-12 (Rhino 8, 8.9.24194.18121, Git hash:master @ 785b9fde79bb684d22aab317998f7195a8c27c14)
License type: Evaluation, build 2024-07-12
License details: Stand-Alone
Expires on: 2024-10-17
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 8GB)
.NET Framework 4.8.9256.0
Primary display and OpenGL: Intel(R) HD Graphics Family (Intel) Memory: 1GB, Driver date: 10-16-2017 (M-D-Y). OpenGL Ver: 4.3.0 - Build 20.19.15.4835
Primary OpenGL: Intel(R) HD Graphics Family (Intel) Memory: 1GB, Driver date: 10-16-2017 (M-D-Y). OpenGL Ver: 4.3.0 - Build 20.19.15.4835
> Integrated (slow!) graphics device with 3 adapter port(s)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.3 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.3
Shading Language: 4.30 - Build 20.19.15.4835
Driver Date: 10-16-2017
Driver Version: 20.19.15.4835
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24194.18121
Well, your integrated video card is way under spec for Rhino - even Rhino 7, surprised that it runs - and your video drivers are almost seven years out of date. You might try and update the drivers, but I still doubt it will run well if at all.
This may be helpful to update the Intel video driver: Updating Intel HD Driver
