I started having some fun with V8 yesterday and found this.
There is quite a difference between these two display modes in V7 to V8 of Rhino.
Same model, Isocurves are turned on on both of them. There are no special files for the background.
Also, the I cant get rid of the cplane. It seems like there are 2 cplanes. One you can remove and one you cannot.
It successfully reverts the custom display mode settings all the way back to Shaded. It is simply a copy of the Shaded display mode.
On the plus side, the Cplane is now fixed.
Maybe if the grid and the axes had separate transparency parameters, then there’d be a workaround with that, and maybe if the scaling were separate or if the axes scale could be more than 100%, then there’d be a way to trick it, but nope…
