Rhino 8 display mode doesn't show per face colors (worked in Rhino 7)
What am I missing here? I imported the view mode from Rhino 7 and then tried to find the issue but so far I can’t see anything different…
Display mode is this one.
Bump. I still see this issue in V8 SR14.
Anyone know what’s going on?
@eobet When I try to load that I see this, which seems to do what you want.
I exported it again from Rhino 8, does this work as expected?
Design.ini (15.4 KB)
No it does not (and I’m using the SR15 you sent me earlier now).
Do any of the objects in your image have per face colors? All I see are layer colors.
@eobet can you post a polysurface with per-face colors that shows correctly in 7 and not correctly in 8 using these settings? Something as simple as a box would do. I want to have a model we can all base our observations/findings on.
Ah darn, reading the title of a post actually helps.
Digging to see if I can find where it comes from.
Looks like Ambient Occlusion is messing it up, can you confirm @eobet
RH-85579 Ambient occlusion on hides per face colors
PerFaceColors.3dm (52.6 KB)
Yup, confirmed!
RH-85579 is fixed in Rhino 8 Service Release 17
