Rhino 8 Custom preview component / "Only draw preview geometry" BUG
Hello everybody!
I noticed a bug when using Custom preview and the “Only draw preview geometry for selected objects” option.
So when user has the “Only draw preview geometry for selected objects” option on, all the “custom preview” objects are shown as grey.
This happens to me as well. At least in Shaded and Ghosted mode. Something is off.
See this thread on the same topic: Grasshopper's custom preview broken in Rhino 8 WIP?
There are a couple issues, but no clear reproduceable bug afaik.
Hi there!
I am experiencing the same issue with Rhino 8, 8.8.24149.1500.
Moreover, Rhino (8) sometimes crashes if I open a GH script that has Custom Preview enabled.
Cheers,
Miru
I’m not seeing any crash reports from you. Does the crash reporter pop up when you experience this?
Hi wim!
I have not sent crash reports since the program went into blue wheel of death mode and then the programm asked to close.
today it didn’t crash - i also did the latest candidate update - probably due to it all went wel…
I will report if anything similar happens again.
Thanks for looking into this :blush:
Cheers,
Miru
Hi @Nikke_Tapanainen, @miruna.vecerdi
I’m testing on 8.13 and I’m unable to reproduce it.
Do you mind updating and confirming this works on your side too?
Hello @kike
Just tested it. now it is working like it should be.
Thank you for checking :slight_smile:
