I have run the same GH file in Rhino 7 & 8 for mac.
Change the display mode to Rendered in Rhino and in Grasshopper disabled the preview on the custom preview component, and left Render enabled.
The outcome is Rhino 7 works and Rhino 8 does not.
I believe I just logged this earlier today: RH-82108 Custom Preview and Create Material cause display issues
I have the same issue. My script generates a custom PDF with 3D preview of the model and with annotations. I can’t really understand what’s going on, but I have noticed following:
SystemInfo.txt (2.9 KB)
The bug is still open, not yet fixed.
Hi there!
I have the same issue. Moreover, if the Custom Preview
is unabled and you enable it while Rhino is in rendered Preview, Rhino (8) stops working.
Hi Miruna -
I’m not seeing that here. Could you post the output from the Rhino SystemInfo
command and a simple .gh file that we can try?
Hi wim!
I now realise that this is a space for Mac topics - and I am experiencing this issue in Windows.
oops
This error doesn’t always happen, at least not with simple cases. Please refer to the YT item - this issue exists on both Mac and Windows.
Still occuring. Very frustrating. No workaround. Entirely ruins my workflow. The object sometimes appears and sometimes does not.
What sometimes helps:
Begging for an update. Thanks.
RH-82108 is fixed in Rhino 8 Service Release 14
I am having this same issue - even with the latest service release. Any geometry displayed with Custom Preview disappears from the viewport in rendered mode - unless I switch off “Shadows” in the General Settings for Rendered Mode. The issue seems to come and go though…, and if I actually Render the scene with the Rhino Renderer, the geometry is displayed.
Any suggestions?
