Save changes MsgBox
Found a little issue when closing a modified drawing when Rhino is minimized. The “Save changes” MsgBox isn’t visible when Rhino is minimized.
Step to reproduce
-Modify a drawing so Rhino will prompt you with the “Save changes” MsgBox when closing
-Minimize Rhino
-Right click the icon in the taskbar to close Rhino.
-The “Save changes” MsgBox isn’t visible.
-At this point if you restore Rhino the MsgBox isn’t visible but hitting Esc will close the MsgBox so you can continue.
Windows 11, Rhino 8 SR28
TJ
