Hello All,
Printing a Solid Fill Hatches from a layout works well in V7, meanwhile it is broken in V8:
1- Below is a snipped from V7 that shows the contents of a layout being printed correctly:
2- Unfortunately, the results seem to be broken in V8, you can see any solid hatch pattern that has some sort of a nonlinear boundary will fail. (this issue is exclusive to details on layouts)
Attached is the file that you can test the investigate the bug yourself.
Print Me!.3dm (2.9 MB)
