We just updated our Rhino from 7 to 8 today. I changed to Dark mode immediately, however, when I tried to print multiple Layouts, on dark mode it is not possible to deselect layout pages, when I changed back to regular mode I was able to deselect it normally.
Yes, they all came selected and I was unable to deselect then clicking on the check marks, nothing happened at all and printing would always print everything.
The file was one that I started drawing on Rhino 7, I don’t know if that can be the reason.
I am using Version 8 SR3
(8.3.24009.15001, 2024-01-09)
Also, when resizing the Dot window, the secondary text part stays locked while everything on top of it can get hidden.
Minimum size
Yes it is stupid, but for some reason my coworker needed to ask for help before trying to resize the window
Hello- the Dot behavior is by design in that, previously, only the bottom , secondary text, could be resized and the top was fixed, making it awkward to use if there is a lot of text in the dot. However, there should be a minimum size in the top window, I’ll see if we can fix that.
Here, in ourt latest, the top field in Dot has a minimum size, it will not disappear.
well, my choice for minimum size would be having one line of text on each text box.
About the printing issue I reported, looks like it might have been the fact that I hadn’t saved the file as Rhino 8 when trying to print, after saving it and selecting to overwrite as Rhino 8 the issue is gone.
