Rhino 8 Beta - Viewport Stutters with Turntable
Hello All
System Info
Rhino 8 SR0 2023-9-28 (Rhino 8 BETA, 8.0.23271.13233, Git hash:master @ 4acd4a788d5f9e7999c3d49c07cdd2f60038b920)
License type: Commercial, build 2023-09-28
License details: Cloud Zoo
Expires on: 2023-11-12
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
.NET Framework 4.8.9181.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 7-11-2023 (M-D-Y).
- Windows Main Display attached to adapter port 1
- Secondary monitor attached to adapter port #2
Primary OpenGL: NVIDIA RTX A1000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 5-30-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 529.08
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-30-2023
Driver Version: 31.0.15.2908
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.0.23271.13233
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23271.13233
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23271.13233
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23271.13233
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23271.13233
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23271.13233
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23271.13233
I noticed this issue generally with my spacemouse thinking it was a driver issue, but now it looks more evident that there is something you need to look into.
1- Start with empty file
2- Create a box
3- Run Turntable with a value of 14
some stuttering will happen especially with the mouse movement.
See video below
Update : Resetting Rhino Options and Removing third party plugins solved the issue.
my job now is to find the bad guy.
Update 2
Re-imported Rhino Options Brought back the issue.
Update 3
It is the Cursor Tooltips.
Disabling:
“Rhino.Options.CursorToolTip.CommandPromptPane” Solved the issue.
Thank you for Reading
Interesting; @jeff maybe we should temporarily disable cursor tooltips while turntable is active. What do you think?
It can be a good solution. I just disabled it altogether since it affects the smoothness of my Spacemouse as well.
