Are there any settings in Rhino 8 WIP that can be tweaked to revert the graphics setup/performance of Rhino 7? Rhino 7 seems to run much faster (viewports, multiple detail views on the sheets) and Rhino 8 seems to freeze all the time.
It would be very helpful as I’m trying to use new features, but these slow graphics make it very difficult.
Rhino 8 is still in WIP, but it may be making more intensive use of some GPU features that it’s just not up to snuff for, it does date to 2017 and 5GB VRAM is not officially considered adequate for multiple monitors with Rhino…it’s more or less a 1060 with more RAM?
Makes sense, thanks @JimCarruthers. I will try to switch the workstation then.
I imagine that in the meantime there is no way to remove some of these “GPU features”? They are not listed anywhere by any chance in any of Rhino’s options?
I may be out of luck finding another machine with higher specs (unless Nvidia suddenly open sources their drivers ), so still happy to learn about any alternative way to revert graphics performance in Rhino 8 back to 7.
just curious if it is known and acceptable to have Rhino 8 is always slower between (10% - 30%) compared to v7 when it comes it viewport performance. or is it still in the works? and If people are okay with this how can this presented to the end users when it comes to “Performance Improvements”
Rhino 8 SR0 2023-8-1 (Rhino WIP, 8.0.23213.14305, Git hash:master @ 0b67a0b3062ce94adf40f027fd9fa82c657ec0f7)
License type: Commercial, build 2023-08-01
License details: Cloud Zoo
Expires on: 2023-09-15
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 1.3e+02Gb)
Computer platform: DESKTOP
Primary display: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 7-12-2023 (M-D-Y).
Primary OpenGL: NVIDIA A40 (NVidia) Memory: 48GB, Driver date: 7-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.67
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-12-2023
Driver Version: 31.0.15.3667
Z-Buffer depth: 24 bits
Total Video Memory: 49140 MB
C:\Program Files\Doliwa Workshop\Rhino Nature\Rhino Nature.rhp "Rhino Nature" 1.0.2.42286
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp "Commands" 8.0.23213.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.0.23213.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.0.23213.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8 WIP\Plug-ins\MeshCommands.rhp "MeshCommands" 8.0.23213.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.0.23213.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp "RhinoCodePlugin" 8.0.23213.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.0.23213.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp "SectionTools"
Here is a file that I work on and I can feel the performance degradation (on shaded mode), It is a Revit Export that has a lot of blocks, the performance disparity continues as I explode these blocks
I’m not seeing that here. When I open your model in Rhino 7, I get 5.43 FPS from TestMaxSpeed. In Rhino 8, I get 7.48 FPS. Which results are you getting?
This is on a PC with an NVIDIA RTX 3070 on a 4K screen. Both times Rhino was in full screen with no other programs running. The file was opened as is and TestMaxSpeed was run.
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 7-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.67
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\SimLab\Plugins\SimLab USDZ From Rhino\SimLabUSDZExporter.rhp “SimLab USDZ Exporter”
C:\Users\seltz\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Grasshopper2\2.0.8609-wip.28470\Grasshopper2Plugin.rhp “Grasshopper2” 2.0.8609.28470
After exploding the Block instances, I get these numbers:
Rhino 8: 33.68 FPS
Rhino 7: 36.36 FPS
The next steps for me are to 1- completely uninstall V-Ray 5, not just disabling the plugins, hopefully this can help a little bit, 2-Reset all the options / UI customizations that I made to Rhino 8 to narrow down the disparity.
one possible cause for that is also because I run a 2nd GPU as my OpenGL processor, will test it without a 2nd GPU as well
*** Update,
1- Uninstalling V-Ray didn’t make a difference since it was already disabled in the Plugins Manager.
2- Disabling my OpenGL GPU (Nvidia A40) and Keeping my RTX 4000 doing all the heavy lifting, it seems the margin of disparity has been shrunk to the below:
V7. 12.95 FPS
V8. 12.55 FPS
I’ll test my work machine tomorrow to get more information.
