Rhino 8 Beta on Mac - Weird UI Issues
I’ve just recently started trying out the Rhino 8 Beta on Mac - I’m a longtime Rhino user on Windows but trying this out on my home Mac for comparison. I’m facing some odd UI issues that make me wonder if I have something set up incorrectly.
  • The first mouse click doesn’t seem to register. Snaps are recognized correctly, if I try to draw (for example) a rectangle from one intersection point, I have to click twice to start the command. The first click sees the snap, but doesn’t start the command. I have to snap a second time in the same place to start the command. After the first point it works as expected - I can draw an n-point polyline and snaps work correctly for the second - n points.
  • typing units is (sometimes) interpreted as ending the command. If I try to draw a line 6’8" long, it will be 6 (feet) long. If I try to enter this as 80" it will be 80 (feet) long. If I explicitly click into the Command field to enter text it works correctly, but if I start typing normally without clicking into the input field I have issues.
  • Input text focus is erratic. On windows If I start typing it goes to the command input, no problem. On the Mac sometimes text input goes to the command, other times it doesn’t.
Here’s my install info:
Rhino 8 SR0 2023-10-24 (Rhino 8 BETA, 8.0.23297.13304, Git hash:master @ 4368ce4c82870d4ce7b0ef004198da23d48ffe5f)
License type: Commercial, build 2023-10-24
License details: Cloud Zoo
Expires on: 2023-12-08
Apple macOS Version 13.0 (Build 22A5342f) (Physical RAM: 32Gb)
Mac Model Identifier: Macmini8,1
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon RX Vega 64 (8 GB)
LG HDR 4K (3008 x 1692 @ 60.00Hz)
USB devices
Apple: Headset
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/Applications/RhinoBETA.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23297.13304
Hmmm - for what it’s worth I ran the ‘Reset’ Command and that solved my issues.
