Rhino 8.8 SRC 1 Crashes after Grasshopper initialization
Rhino 8.8.24135 crashes after Grasshopper initialization - sort of crashes, because I can just close this crash dialog and still use Rhino, but I can no longer use Revit… Rhino 7 with the same RIR build seems to work ok.
System Info
Rhino 8 SR8 2024-5-14 (Rhino 8, 8.8.24135.14001, Git hash:master @ 8c191427bc5c6c4e62f523a752d809f68897c3a5)
License type: Educational, build 2024-05-14
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9232.0
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z-Buffer depth: 24 bits
Total Video Memory: 11520 MB
C:\Program Files\Rhino 8\Plug-ins\RhinoToGrasshopper\RhinoToGrasshopper.rhp “RhinoToGrasshopper” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.2.0.0\bella_rhino.rhp “Bella” 24.2.0.0
C:\Users\Czaja\Desktop\Rhino_7_Win_2023.0417\HDRLightStudioTexture.rhp “HDRLightStudioTexture”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.4.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24135.14001
Using RIR 1.22.8895
Please send in a crash report with your contact information if possible. We are trying to find the cause and will release a fix as soon as we understand what broke.
Thanks,
-Steve
I find that if I have two instances of Rhino open, start GH in one, hard crash with no report dialog (= sorry, can’t send a crash report). Then, in the other instance of Rhino, I can start GH successfully.
SystemInfo-R8
License type: Commercial, build 2024-05-14
Windows 10 (10.0.17134 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Primary display and OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Primary OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 2-18-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
Is this with Rhino.Inside or vanilla Rhino? I haven’t been able to repeat. The issue above is concerning a possible change that affects Gh Plugins. Thanks for reporting, any additional info is always helpful
Same problem here. Installed Rhino 8.8, and it crashes (fast exit) after GH initialization, also when it’s the first instance to open.
Can’t produce a sysinfo therefore.
8.7 worked fine before that.
Vanilla Rhino, no insides here
In Revit 2024? What happens if you start grasshopper with GrasshopperLoadOneByOne and say no to all 3rd party? Thanks
Anyone with a Crash report would be greatly appreciated, i haven’t been able to repeat in either environment, but i don’t have a lot of plugins loading.
Similar mess below:
R8 SRC 8.8.24135 broke most of my GH plug-ins - McNeel Forum
This should be fixed in the 8.8 release candidate that we shipped earlier today
I installed this latest build and it boots just fine.Thanks!
Getting this error after updating to the newest service release candidate, is there a quick fix?
Yes, there was an update to the Service Release Candidate soon after the Tuesday release with a fix.
the issue persists, i have the very newest release candidate, updated last night
Lets do a repair install on the Link i sent you privately. Does this involve Rhino.Inside.Revit or just standalone Rhino?
