Rhino 8 crashes when opening grasshopper
I’ve had rhino 8 crashes daily everytime I open it the first time. This has happened in my laptop and work computers. I think it might be a pluging, but i’m not sure.
Rhino 8 SR25 2025-10-29 (Rhino 8, 8.25.25302.09531, Git hash:master @ 359fe0009c8a46e684cce2e3d9a861af780e07d9)
License type: Commercial, build 2025-10-29
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 16GB)
.NET 8.0.14
Computer platform: LAPTOP  - Plugged in \[100% battery remaining\]
Primary display and OpenGL: NVIDIA GeForce RTX 4050 Laptop GPU (NVidia) Memory: 6GB, Driver date: 11-6-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.14
Primary OpenGL: NVIDIA GeForce RTX 4050 Laptop GPU (NVidia) Memory: 6GB, Driver date: 11-6-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.14
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 4-28-2025 (M-D-Y).
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-6-2024
Driver Version: 32.0.15.6614
Z-Buffer depth: 24 bits
Total Video Memory: 6141 MB
C:\\Program Files\\Chaos\\V-Ray\\V-Ray for Rhinoceros\\V8\\VRayForRhino.rhp	“V-Ray for Rhino”
C:\\Users\\johan\\AppData\\Roaming\\McNeel\\Rhinoceros\\8.0\\Plug-ins\\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\\D5Conv.rhp	“D5 Live Sync for Rhino”
C:\\Users\\johan\\AppData\\Roaming\\McNeel\\Rhinoceros\\packages\\7.0\\NVIDIADenoiser\\0.4.3\\NVIDIADenoiser.Windows.rhp	“NVIDIADenoiser.Windows”	0.4.3.0
C:\\Users\\johan\\AppData\\Roaming\\McNeel\\Rhinoceros\\8.0\\Plug-ins\\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\\SpeckleConnectorRhino.rhp	“SpeckleConnectorRhino”	2.21.2.16503
C:\\Users\\johan\\AppData\\Roaming\\McNeel\\Rhinoceros\\packages\\8.0\\PlanFinder\\1.3.1\\PlanFinderRhino8.rhp	“PlanFinderRhino8”	1.0.0.0
C:\\Program Files\\Rhino 8\\Plug-ins\\Commands.rhp	“Commands”	8.25.25302.9531
C:\\Program Files\\Rhino 8\\Plug-ins\\rdk.rhp	“Renderer Development Kit”
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoRenderCycles.rhp	“Rhino Render”	8.25.25302.9531
C:\\Program Files\\Rhino 8\\Plug-ins\\rdk_etoui.rhp	“RDK_EtoUI”	8.25.25302.9531
C:\\Program Files\\Rhino 8\\Plug-ins\\NamedSnapshots.rhp	“Snapshots”
C:\\Program Files\\Rhino 8\\Plug-ins\\MeshCommands.rhp	“MeshCommands”	8.25.25302.9531
C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoCycles.rhp	“RhinoCycles”	8.25.25302.9531
C:\\Program Files\\Rhino 8\\Plug-ins\\Grasshopper\\GrasshopperPlugin.rhp	“Grasshopper”	8.25.25302.9531
C:\\Program Files\\Rhino 8\\Plug-ins\\Toolbars\\Toolbars.rhp	“Toolbars”	8.25.25302.9531
C:\\Program Files\\Rhino 8\\Plug-ins\\3dxrhino.rhp	“3Dconnexion 3D Mouse”
C:\\Program Files\\Rhino 8\\Plug-ins\\Displacement.rhp	“Displacement”
C:\\Program Files\\Rhino 8\\Plug-ins\\SectionTools.rhp	“SectionTools”
start by disabling all plugin that do not ship with Rhino.
restart Rhino and see if it crashes.
if not, enable one of the plugins that do not ship with Rhino (only one)
restart Rhino and see if it crashes.. repeat this will all plugins.
my bet is that D5 live sync is the bad actor (seen it before) but it could be any of the add ins.
once you identify who the bad actor is, simply disable that one, and look to the developer of that plugin for an update or tech support for that particular plugin.
Hi Johan -
By “it”, I take it you refer to Grasshopper?
If so, to troubleshoot issues when launching Grasshopper, you can use the GrasshopperLoadOneByOne command to block certain plug-ins to find out which one is causing the crash.
