I found the problem… Fix will be in the next 8.x WIP… (some time tomorrow).
Thanks for reporting this!
-Jeff
-Jeff
To this just plain user this terminology is confusing. For me WIP is 9.x and 8.x RC’s come out on tuesday.
I would also like to add that I have the feeling that objects in RH8 look shaper/beter/cleaner then in RH7.
This of course is nice when work in small drawings. But when working in bigger drawings this will bring performance issue’s. I wouldn’t mind (just like in games) a worse video/display quality but keeping a high performance.
I don’t know if this kind of mechanism could be build for Rhino but I think it could improve performance.
Thnx Jeff,
Looking forward to this!
With the model I tested it with for the YT, speed has gone up from 1 fps to 12.6 fps. @Martijn if you want I can send you the daily build to test this out in pm
Sure, lets do it!
Were back baby! This works great.
Let me run the same tests as before:
That one step file:
With blocks:
With Isocurves:
Time to regen viewport 100 times = 10.66 seconds. (9.38 FPS)
Without Isocurves:
Time to regen viewport 100 times = 8.89 seconds. (11.25 FPS)
Without Isocurves and without edges:
Time to regen viewport 100 times = 7.50 seconds. (13.33 FPS)
After _ExplodeBlock
With Isocurves:
Time to regen viewport 100 times = 8.08 seconds. (12.38 FPS)
Without Isocurves:
Time to regen viewport 100 times = 4.62 seconds. (21.62 FPS)
Definitely a lot better. Only big change is without block and isocurves.
For now my problem has been solved!
RH-83267 is fixed in Rhino 8 Service Release 11 Release Candidate
