Hi all, Just reporting some minor, odd bugs:
In Pen or Monochrome Mode, the clipping-plane display shows me odd results:
When using Solid fill full Black, it looks as expected:
However, if I go to any other color than full black, it shows a transparent-ish-effect where I see the shadows of the ‘inside’ faces (I suppose maybe the same thing is happening when its Black, its just that I can’t see them in that case cus’ its black shadows on black fill?)::
Also, if I go to anything other than Solid fill, the lines do not show up at all in Monochrome mode.
The line-work clipping-plane hatches do work in Pen mode however, it is just an issue in Monochrome mode.
Environment:
- Macbook 2021, Apple M1 Max
- macOS 13.6.1 (Ventura)
- Rhino Version 8 (8.3.23360.13002, 2023-12-26)
Example file attached if its helpful.
All the best,
@ed.p.may
example.3dm (3.9 MB)
