Maria_Nasr
(Maria Nasr)
December 17, 2024, 11:13am
1
Hi everyone,
I’ve been having some trouble with the Monochrome view in Rhino. The line quality and shadows look really poor, especially when zoomed out. Fully zooming in seems to improve it slightly, but even then, it’s not as clean as I’d expect.
I read somewhere that this could be related to antialiasing, but I noticed that in the new version of Rhino, this option is no longer available as a manual setting.
Does anyone have suggestions for improving the line quality and shadows in Monochrome view? I’d love to figure out how to achieve cleaner, crisper visuals.
Thanks in advance!
wim
(Wim Dekeyser)
December 17, 2024, 11:22am
2
Hi Maria -
Could you post the following:
The output of the Rhino SystemInfo command
A 3dm file that can be used to troubleshoot the issue
A screenshot of what it looks like on your screen
Maria_Nasr
(Maria Nasr)
December 19, 2024, 10:51am
3
Of course! Here you go
I attached a screenshot of what I get plus the 3dm file (Rhino 8).
Below is my system info:
File Issue.3dm (9.2 MB)
](https://)Rhino 8 SR14 2024-12-10 (Rhino 8, 8.14.24345.15002, Git hash:master @ cdb74b46090a23fe242c51b288886f76467a741b)
License type: Educational, build 2024-12-10
License details: Cloud Zoo
Apple macOS Version 14.7 (Build 23H124) (Physical RAM: 36GB)
Mac Model Identifier: Mac15,10
Language: en-LB (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M3 Max
Color LCD (1512 x 982 @ 120.00Hz)
GPU Vendor: Apple
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/marianasr/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/KeyShotRhinoPlugin.rhp/libsceneapi_wrapper_rhino.dylib
/Users/marianasr/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/KeyShotRhinoPlugin.rhp “KeyShotRhinoPlugin” 1.0.0.0
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.14.24345.15002
wim
(Wim Dekeyser)
December 19, 2024, 11:06am
4
Hi Maria -
Thanks.
I’m on a similar machine, an Apple M3 Max, and opening your file here, it looks like this:
I’d go to the Rhino Settings → Display Modes, pick Monochrome from the list and use the Restore Defaults button. If you want to use your customizations, you can save the modified display mode as a custom mode first.
Maria_Nasr
(Maria Nasr)
December 19, 2024, 11:22am
5
Hello ! I just tried that and the result is pretty much the same
The lines are super blurry and I need to use the picture in a presentation …
wim
(Wim Dekeyser)
December 19, 2024, 4:04pm
6
Hi Maria -
You could use the ViewCaptureToFile command and set the scale to, e.g., 2 to make a larger version in which the edges will be thinner.
