Clipping Plane Fill Color doesn't change in Monochrome Display Mode
Im trying to change the clipping plane fill color in the Monochrome display view but it doesnt works.
I’ve confirmed that the objects being cut are closed polysurfaces.
For example, the box on the left is being clipped by the clippingplane, but the fill color is white instead of green.
Hi Ignacio -
That seems to work fine here:
Please run the Rhino SystemInfo command and copy-paste its output here.
Apart from this, though, wouldn’t you want the same section style (color and possible pattern) in all display modes? That’s typically set by changing the layer’s section style properties.
Hi Wim, first of all thank you for helping me.
What I’m trying to achieve right now is to create different display modes with custom background colors and fill colors for each one, so that the section fills look different depending on the display mode I’m using.
That’s why I was trying to set the fill color directly in the display mode settings, rather than using the section style from the layer.
This is the SystemInfo text:
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13001, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Commercial, build 2024-03-12
License details: Stand-Alone
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4070 (NVidia) Memory: 12GB, Driver date: 4-12-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 576.02
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-12-2025
Driver Version: 32.0.15.7602
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Users\nacho\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.12.0.0028\Rhino 8\D5Conv.rhp “D5 Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24072.13001
Thank you.
You should upldate to the latest service release, you’re missing out on more than a year of fixes and improvements.
Yeah mate, I just did it and works perfectly I dont know what I was thinking haha.
Thank you.
