Rhino 8.24 on windows freezing, keeps running after being closed
Rhino 8.23 freezes my system: it hangs for a while, Explorer usually crashes (its windows have to be reopened), but in a minute or so the system responds again, only to freeze maybe few minutes later. After closing the Rhino instance, Rhino keeps running in the background, hogging the CPU!
I noticed it happens after I’ve started adjusting material of a layer.
With other file it helped that I put only the strictly necessary geometry into a new blank document.
Windows 10, I have an old Radon RX Vega, the latest driver
SystemInfo
Rhino 8 SR23 2025-9-8 (Rhino 8, 8.23.25251.13001, Git hash:master @ e75a9d62e23cc6f52d4ef68eb7eda9f8da9b6cd9)
License type: Commercial, build 2025-09-08
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 48GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: Radeon RX Vega (AMD) Memory: 8GB, Driver date: 7-1-2025 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 25.8.1.250617
Accelerated graphics device with 7 adapter port(s)
  • Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 7-1-2025
Driver Version: 31.0.21923.11000
Z-Buffer depth: 24 bits
Total Video Memory: 8119 MB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.5.4.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.23.25251.13001
Could you give it a try with Rhino 8.24 ? Thank you.
It still happens on 8.24
I just change layer material, Rhino hangs, music in the background hangs soon after, then eventually windows resumes working. I close Rhino, it still goes on eating CPU time before I kill the process.
Hi -
Please run the Rhino SystemInfo command and copy-paste its output here.
SystemInfo again
Rhino 8 SR24 2025-10-8 (Rhino 8, 8.24.25281.15001, Git hash:master @ ba28668a8431990c700173e46ef2dbcb873cf092)
License type: Commercial, build 2025-10-08
.NET 8.0.14
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.24.25281.15001
after many updates, Rhino 8.31 seems to have finally fixed this, thank you
