Hi, I’m having some troubles launching my Rhino program that’s been downloaded directly from the Mcneel website. I have tried using the shortcut, file location, apps folder to launch the program but it wouldn’t launch until at least 15 tries later. I’ve checked task manager to look at the progress of launch but it usually stops at 34MB.
Is there a way to fix this? I believe I have messed around with the Host Editor and that is what causing this problem, how can I fix the host back to default? Thanks!
It’s really hard to diagnose without seeing system information.
1- Have you tried to do a fresh install?
2- Can you right click on Rhino icon and select “Run as Administrator”
3- once you are in rhino please type “Systeminfo” and paste your information here.
I was using a copy of the software from my friend and have just removed it, now the fresh install would not work at all. I’ve tried to run as administrator but it still doesn’t launch. When I try to open the file location, it’s still dated to when I installed the copy from my friend and not a new file, though I have already uninstalled the software… How do I get rid of the old ones completely and let it run fresh?
go to apps and features, select rhino and click on uninstall, If your friend gave you a cracked version, some of that my stay in your machine and may require you to manually delete these files, since they may cause a major harm to your machine.
I have already uninstalled the software and redownloaded a couple times… Any tips on what files I should be deleting? I’ve already tried to delete most files that I can find. Also, how do I reset the host to default settings?
I’ve tried doing that by right clicking the downloaded software and through Rhino installer, modified and repaired but it still doesn’t work. Is there a way to repair the .Net install manually?
I have updated my windows 11, it is totally up to date. I am trying to open Rhino 7 but just the launch page pops up for a couple of seconds and then vanish. I am only able to open Rhino 7 in Safe Mode.
However it doesn’t include very basic and necessary features of Rhino, which are frequently used. This is making it difficult for me to learn the software.
I request you to please help me solve this issue.
