Rhino 7 not opening on windows 11
Hello, is anyone encountering this issue? Rhino is neither working nor opening on windows 11. Anyone knows how to fix this??
Have you tired Safe Mode?
yes same result it doesn’t open… although on windows 10 everything was working
In Windows Device Manager, in Display adapters, do you have one named “Citrix”?
Nope
Does Check for Updates report anything needs to be installed?
Have you restarted Windows?
my system is up to date with the latest windows updates. yes i’ve restarted many times and uninstalled then installed rhino 6 and 7 still same issue… only one version of rhino 6.13 opens but the toolbar is not here and plugins too… not even in the options.
i even try to run toolbar commands and it tells me unknown command. is rhino supported on win 11?
We’ve done some simple, basic testing and did not have any issues.
As far as I know, you are the first one to report problems.
Win11 is basically a glorified service pack, it should work fine.
But common commands suddenly being ‘unknown’ sounds like your Rhino install has become screwed-up–which has happened to me once, nothing to do with a windows upgrade–so next try doing a repair on it.
yes it seems so… i repaired it twice it downloaded net framework but then it wont open it tells me there’s a license problem. All these problems weren’t present in windows 10 so i’m thinking of downgrading now.
License problem? You probably just need to log in to your rhino account.
if i dont repair it it gives me errors with plugins, a missing toolbar and unknown commands. when i repair it gives me an error with license manager without even opening rhino
Screenshot 2021-11-27 205457
Uploading: Screenshot 2021-11-27 205217.png…
I think your Windows .NET framework is borked.
This is a great tool but I do not know if it’s okay for Win 11:
it seems windows 11 is the problem… i ran it but it’s unable to work
Has there been a solution to this? In August 2022 I updated to W11 and Rhino 7 v2.1 is currently on the machine. It seems the only way to launch the app, though it’s inconsistent, is to go to the app folder and repeatedly attempt to launch the app with admin privileges. Any fixes yet?
What version of Rhino??
Your issue sounds completely unrelated to the problem here. There is no general problem running Rhino on Win 11, there would be evidence here.
The issue is that Rhino won’t launch through shortcuts or going to the exe file. Repeated attempts and only with admin will get it going. The version is Rhino 7, build 2.1
Run SystemInfo and post the results. Build 2.1?? We’re up to SR23 now.
Rhino 7 SR22 2022-9-12 (Rhino 7, 7.22.22255.05001, Git hash:master @ 196b1bc7dd093321e28dcc7a2bb8709a9bebe12d)
License type: Commercial, build 2022-09-12
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P1000 (NVidia) Memory: 4GB, Driver date: 10-19-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 452.56
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 11-15-2021 (M-D-Y).
- There are no monitors attached to this device!
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
> External USB display device with 8 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-19-2020
Driver Version: 27.21.14.5256
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\djjan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.22.22255.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.22.22255.5001
