I know some already had that kind of issue and I searched the net and tried some solutions given but it didn’t work.
Whenever I try to launch Rhino 7, the app just ignores it even exists.
Rhino safemode launch doesn’t work neither
I have windows family 11 64bits on an ACER NITRO 5 Laptop / 11th Gen Intel Core 5 i5-11400H @ 2.7GHz / 16Go RAM / Nvidia GeForce RTX 3060 Laptop GPU
I have been using rhino for years now and never had any issue. I just happened to update my nvidia pilots two days ago, can it be the source of the problem ?
yes thank you Gianpietro, i have read through and uninstalled the updates but still no change. These updates happened in January also so it does not make sense they would affect me today. But the app simply will not start just like Jonard said this morning. This problem only arose since this morning after i used the app at the weekend and no updates have occurred between those days.
What has been typically working is to Repair the 2015-2022 redistributables (x86 first, then x64), then repairing Rhino 7.
If you get another windows update or install other software you may need to repeat these steps. The microsoft support files have been rather fragile lately.
I had the support tell me to deinstall/reinstall then repair the Microsoft Visual C++ 2015-2022 Redistributable (x64) and (x86) and tadaaaa…. it worked… Thanks for all the answers.
Thank you Jonard, the solution you proposed worked greatly!
I just uninstall the versions of Microsoft Visual C++ 2015-2022 Redistributable (x64) and (x86) 14.44.xxx and installed the newest 14.50.35719, without any repair.
