I updated Rhino WIP (7.0.20210.12505, 28.07.2020) and this message has appeared:
Reinstall plugin and make sure dependencies are available
Unfortunately there are no such plugin “layouts” in Program Files or %appdata% folder .
If i run the command from toolbar (new in 7 - layouts) the message Unknown command _layouts has appeared in the command line.
Hi - as a test, what happens when you use the English version of Rhino?
So I completely unisntall Rhino 7 WIP, install again with English language adde.
In czech version problem persists, after switching to english no message has appeared. After running the command _layouts the side panel is activated with information- Page 1, 210,0×297,0 mm
Thanks for testing that. We’ll have someone look into this.
You can just click on OK each time Rhino starts, it will just cause an issue when using the command Layouts but Rhino will still be working fine for all the rest.
This will be fixed in next release.
Thanks for reporting!!
Cécile
