Rhino: version 7 SR36 (7.36.23346.16351, 2023-12-12) Commercial with VisualARQ: 2.13.2.17721 installed (although I think this is not related to VisualARQ).
When in an empty new file simply clicking on the layers, properties or other pane buttons on the right, Rhino crashes completely.
Is this a known bug or is there something I can do to fix this on my end?
Try turning off ASUS GPU Tweak III and see if that helps. Probably best to exit all of the ASUS tweak and monitoring tools. Anything really that could want to draw on On Screen Display in case crashes still happen.
Other software that can hook into programs like Rhino include: Discord, Steam (the gaming platform), Nvidia Experience (the game recording stuff), audio control software, etc.
It seems to be indeed related to this tool. Rhino 8 has a similar issue with it.
I’m using it to keep the fan on the GPU under control when exporting Rhino architecture designs to TwinMotion. When running TwinMotion, I otherwise have an airplane engine next to me
When disabling the utility, Rhino works fine again.
Thanks again for the advice.
Walter
Unfortunately there is not much we can do here, since the crash happens in that tool. Perhaps you can report a bug to the vendor of the software.
Addendum: I am using FanXpert for fan control on my machine. It is also from ASUS. I haven’t noticed any problems with that though. I just set the ranges and speeds I want them to run at for different temperatures, but I don’t have anything special running outside of that I think.
