I was playing with the shadow settings in a rendered mode. and it keept restarting my computer. and the latest time it reset Rhino 7 back to factory settings, which deleted all my custom dusplay modes.
Windows 10 (10.0.19043 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 5-4-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.77
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-4-2022
Driver Version: 30.0.15.1277
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
it is virtually impossible for user mode code like rhino to crash a machine – it can appear to do so by asking the OS or display driver to do something which triggers a bug in those components, or which uncovers marginal or bad hardware (memory, drive, etc), and so forth
so, assuming this is repeatable, I’d start by simplifying the scenario, first by using just one display, then unplugging other unnecessary peripherals, checking for interesting system log entries in event viewer, running SFC /scannow, checking memory, checking for bios updates (or whether your current bios version has known issues), checking connections generally in the machine, and such, to see if you can narrow down what is causing this behavior
can you look into the WHEA logger in the event viewer? it is like related to hardware instability.? do you have any sort of CPU / Memory or GPU overclock?
Another issue is probably overheating in your system, can you install HWinfo and take a look at the thermals.
Yup… It is core 5 on your CPU (Thread #11)
Core # = Floor (APIC/2)
do you have overclocking on your CPU? do you have an updated BIOS?
Also Are you Running SLI? that’s probably another suspect.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Users\patri\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.11-beta\Substance.Win.rhp “SubstanceImporter” 2.0.11.0
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\patri\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Crayon (43f0446f-00a7-4ff3-864f-0d3af5e47e2b)\1.0.7750.23916\Crayon.rhp “Crayon” 1.0.0.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
Are the shadow settings in one of the “Rhino plugins that do not ship with Rhino”?
If the answer is no disable all the plugins that do not ship with Rhino and reload Rhino. Then test if the problem still occurs. If the problem does not occur then enable one plugin at a time and restart Rhino and test until the problem occurs again.
If the answer is yes disable all the plugins that do not ship with Rhino except the one where the shadow settings are entered and restart Rhino. The test if the problem still occurs. If the problem does not occur then enable one plugin at a time and restart Rhino and test until the problem occurs again.
On paper, your system looks like it should be able to handle pretty much anything, so my money is on this being a hardware issue.
Then again, if this is very file-specific on your system, please upload your file and typical steps to reproduce this. You mentioned playing with shadow settings. Are there other things that cause the system to shut down, or is it very specific to exactly doing that?
