Rhino 7 Shaded View Custom light reverts back to default
Hi all, testing the latest version available, Rhino 7.6.21103.13001, this bug still exists.
As the title says, when I try to apply a custom light scheme in eg Shaded View, it initially gets applied, but since panning the viewport, it resets back to default.
  • Dimitris
Hello- I see this, thanks.
RH-63849 Display modes: Lighting setting is ignored
Rhino 7 just updated to (7.30.23163.13001, 2023-06-12)
This bug where the custimised lighting reverts back to default lighting seems to have returned, When I set the lighting to what I want and press “Apply Now” nothing happens.
Don’t know if this is relevent:
If I press [ok] in customize window and and go back to “Display Mode Options” window then togggle “shade objects” then “flat shade” off then on the correct lighting comes back.
Also I tried saving same model & layout as a Rhino 6 model and the Customised Lighiting “apply now” works fine in Rhino 6. Only seems to fall over in Rhino 7 after this last update.
Another thing I noticed was that when I saved the model as a Rhino 6 model the Display Mode Name I was using when the model was first created (in Rhino 6) reverted back to its original name in Rhino 6. I had changed the Display Mode name in the Rhino 7 version of the model but the name change was not carried back to the “save as” Rhino 6 model.
Logikman
