Rhino 7 saving problem
I am receiving a series of two prompts when I try to “Save” my file. The first says that the file is opened in “read only” mode (when I haven’t opened in that way. After I click ok, I am told the file has not been saved.
Any suggestions to fix? I should add, my Rhino 7 is completely up to date.
Are you saving to a network drive?
Please run the SystemInfo and paste the results here.
My files are linked to Dropbox. But I’ve been doing both and running Rhino for years and this hasn’t been an issue before.
Rhino 7 SR4 2021-3-8 (Rhino 7, 7.4.21067.13001, Git hash:master @ ed629035202f07e8b84a3ee211479ca20bb81b73)
License type: Educational, build 2021-03-08
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P2200 (NVidia) Memory: 5GB, Driver date: 2-23-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.72
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-23-2021
Driver Version: 27.21.14.6172
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.4.21067.13001
Do you see the saving problem when saving to a directory that is not linked to dropbox?
I’ve been working on the same file but saving to desktop for the past few hours and haven’t had the same problem. Hope this helps with diagnosis. I don’t want to have to keep working in this way though (all my files are run through dropbox), so would appreciate a solution to this if you can help - that would be much appreciated.
I don’t want you to have to work this way either. Just trying to diagnose where the problem is. I made some changes to SR5 that may make a difference. Please try the SR5 release candidate and let me know if this fixes the issues you are seeing.
Many thanks - the SR5 has worked.
