Trying to save but "Read Only Mode" error comes up
I am a student running Rhino 7. I have been working on a file for a few weeks now and when I attempt to Save a error occurs saying “File opened in read-only mode. You must use SaveAs to save changes”. Is there a way to prevent that from happening? I have no intentionally turned on Read-Only mode, and I do not want multiple copies of the same file. Any advice would be appreciated
It may be that Rhino has crashed at some point. You’ll probably find a file ending with the extension .rhl. If that is the case remove that .rhl file. You should be able to open the file again in read-write mode.
Hey @nathanletwory, I am getting this bug all the time since ~2 weeks, which is super annoying. The files are definitely not read only and there is no .rhl present.
I would be very happy if McNeel could tackle this, before it never occured to me in this way.
Hi Max,
Please run SystemInfo and paste the results here. I would like to figure out what is causing this issue on your computer.
Hey Steve, here is the SystemInfo.
Any help appreciated, thanks!
Rhino 7 SR5 2021-3-23 (Rhino 7, 7.5.21082.11001, Git hash:master @ 944c103dcfd368bc1974c8866461f0c7bf5ae9d3)
License type: Studentenlizenz, build 2021-03-23
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Plugged in [79% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-18-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1650 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 3-10-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.92
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-10-2021
Driver Version: 27.21.14.6192
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7 WIP\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Users\EFESTWIN\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\1.0.7325.19068\TeDaSharp_040.rhp “TeDAsharp” 1.0.7325.19068
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Users\EFESTWIN\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
C:\Users\EFESTWIN\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\1.0.0\Substance.Win.rhp “SubstanceImporter” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.5.21082.11001
Did you install Hops? If you did, please run PackageManager and make sure you have the most recent version.
Oh yeah this might be the culprit. Indeed the version was a little outdated. After the update I had no such issues yesterday. Fingers crossed that this was it :wink:
Thank you for your immediate help Steve! Greatly appreciated :slight_smile:
I’m having the same issue with saving files. Once I open an old file and try to save it, I get a warning that the file is opened in read-only mode. It also happens when I create new file, save it for the first time and then when I save it again I get the warning. Moreover, the files that I tried to save like that are now borken (no worries, I have backups). The warning says that these are not a Rhino files.
No Hops installed on my system.
I have to stop working because of this issue, so I’m kindly asking for help.
My system setup is:
Rhino 7 SR28 2023-2-20 (Rhino 7, 7.28.23051.01001, Git hash:master @ ecfcd02768bed4b2c815721da70bb5ef985d2796)
License type: Komercyjna, build 2023-02-20
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 1-20-2022 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 3000 (NVidia) Memory: 6GB, Driver date: 8-4-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 513.63
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 8-4-2022
Driver Version: 30.0.15.1363
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Users\Biuro\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23051.1001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23051.1001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23051.1001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23051.1001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23051.1001
C:\Users\Biuro\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
Hello. I’ve been having the same problem with Rhino8 for a few days now. When I save a .3dm file and overwrite the open file, it shows me a message that the file is read-only. After exiting Rhino, I can’t do anything with the file. It can’t be opened, copied, or deleted. The same problem occurs with the file exported to .stp.
I can only open, move, or delete this file after the computer administrator grants me access to it.
SystemInfo:
Rhino 8 SR15 2025-1-13 (Rhino 8, 8.15.25013.13001, Git hash:master @ 424331904354085c3cb84eda50bc6e3d92d470f4)
License type: Commercial, build 2025-01-13
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 48GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: Radeon ™ Pro WX 5100 Graphics (AMD) Memory: 8GB, Driver date: 2-20-2024 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 24.Q1.240216
> Accelerated graphics device with 7 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 2-20-2024
Driver Version: 31.0.21912.14
Total Video Memory: 8135 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.15.25013.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “PrzeglądarkaWWW”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “BezczynnyProcesor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.15.25013.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.15.25013.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.15.25013.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.15.25013.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.15.25013.13001
Hi Piotr Wezik,
Are you saving to a local , networked or cloud location?
Does unchecking the .rhl file locking (restart Rhino after changing) change the behavior?
actually the .rhl file wouldn’t affect stp, so this is more likely something to do with the permissions
Today I tried exporting a simple cube to various formats: .stl, .dwg, .obj, .igs, .x_t, .x3dv, .dxf, and .stp. Only when exporting to the .stp file, access is blocked by the administrator.
I save files to my local drive on the desktop and to a USB drive. I am the only user of the computer - administrator account. The problem appeared a few days ago. Maybe after the last Windows or Rhino update, some kind of block occurred?
If you have Windows Defender active you could try whitelisting Rhino and see if that helps.
I don’t use Windows Defender. If it were blocking Rhino, I think every file saved in Rhino would be blocked, but now only .stp and overwritten .3dm files are blocked.
I probably should have said Windows Defender or any other security software. These software can selectively block actions from software if they find based on their heuristics that the software is malware. Fingerprints and such for code somehow create a match in their database. Often whitelisting Rhino will help in that case.
But if you are not using any security software and you have everything from Windows Defender completely turned off then I have no clue.
I’m using Comodo, but I just tried disabling the protection and the problem still exists.
