Rhino 7 render: Cut out Decals by color mask, how?
Hi…,
is there still a way to cut out surface areas by decal transparency?
Where is the cut out option?
Thanks
Michael
www.flexiCAD.com
Such a feature does not exist for decals.
Instead use planar mapping on that object and apply the image as a texture on a material and assign that material to that (sub)object.
tube_box.3dm (4.0 MB)
Hi Nathan,
thanks a lot.
Decals had an cut out/transparent option in the Flamingo render in the past.
Will you add this for Decals as well?
Thanks
Michael
I doubt this will be a feature for decals, since they are supposed to be only an addition to the basecolor (essentially). @andy, is this something you’d consider? I personally think it’d cause only trouble to no end with conflicting settings between materials and decals.
