hello.
I discovered in Rhino 7 that in 3d view if I change the projection from perspective to parallel the right click button does not rotate the view. Instead, it pans the view. Can I change this behavior as in rhino 6?
It should still rotate around unless it is in a “Plan” orientation; looking down the Z axis.
Press and hold Ctrl+Shift and right-mouse rotate the view.
Then you can right mouse rotate again.
ok with Ctrl+Shift and right-mouse I rotate the view.
But after that still not able to rotate with the right mouse.
I found a solution.
I reset all settings and now it worked.
Maybe I changed something, or a plugin wasn’t able to update in rhino 7.
Thank you anyway.
