RMB rotating Front and Side views?
don´t know why suddenly when i use right mouse button on front or right view it rotates the view instead of pan command
07
any idea? Thanks!
Do you also have this when you explicitly set the view to e.g. Front?
Can you send a file that shows this behavior?
Can you send _SystemInfo?
Thanks for answering,
it happens only on Front and Right view no matter if its a new file or an old one, it does not happen on top view. I’ve never had an issue like this, and i use Rhino since v2… It began yesterday
rotate_view_issue.3dm (163.6 KB)
System info:
Rhino 7 SR25 2022-11-22 (Rhino 7, 7.25.22326.19001, Git hash:master @ 2a680490f96a04550d1f39158b859c4f7739d024)
License type: Comercial, build 2022-11-22
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 11-13-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 526.98
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-13-2022
Driver Version: 31.0.15.2698
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\0.1.0.0\TeDaSharp_050.rhp “TeDAsharp” 0.1.0.0
C:\Program Files\Doliwa Workshop\Rhino Nature\Rhino Nature.rhp “Rhino Nature” 1.0.1.18266
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\CommandTracker\7.0.8201.28462\CommandTracker.rhp “CommandTracker” 7.0.8201.28462
D:\00 RESOURCES\080_RH7\crayon111\Crayon1.1.1\Crayon.rhp “Crayon” 1.1.0.0
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.0\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.1.0.0
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.25.22326.19001
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.25.22326.19001
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.25.22326.19001
Odd that it only happens in Front and Right
The file you sent looks to behave normal here and I don’t see anything different than default in those viewports.
Can you try any of the following:
  • Run _4View twice
  • does it also happen if you disable the plugins that don’t ship with Rhino?
  • does it also happen in safe mode?
  • does it also happen if you use another mouse?
  • does it also happen in another template?
Just tested this:
** Run _4View twice* - It behaves the same, RMB rotates views (Front & right)
** does it also happen if you disable the plugins that don’t ship with Rhino?* - Yes, it does
** does it also happen in safe mode?* - No, it doesn’t.
** does it also happen if you use another mouse?* - No, it doesn’t
** does it also happen in another template?* - Yes, it does
i’m thinking its related to my rhino options, i use a personal scheme for designing and the standard scheme for teaching. If I load my personal *.ini on a new scheme the issue appears but i cannot identify the problem source
Thanks again!
if you can send the .ini I can have a look if there is something I can spot.
i’ve loaded this elements only and no problem:
i was loading one at a time waiting to find the problem
anyway here’s the ini file
nachetz_rhino_2023_01.ini (317.7 KB)
1000 thanks again @Gijs
I cannot repeat the behavior here with your ini, but I see that AlwaysPanParallelViews is set to no, can you see if that makes a difference if you set it to yes? (it’s in Options > View)
if i change to yes something weird happens:
on front and right view the grid changes to World Top…
I think it’s time to make a new scheme from scratch :wink:
Normally, rotating a Perspective projection view in a Plan display is not possible enless you hold Ctrl+Shift and RMB
i’ve been using RMB for years for PAN on front and right view with no issues… I’m not trying to rotate a perspective projection…
I create a new empty file, go directly to front or right view and press only RMB and it rotates the view in parallel mode. It happens since yesterday, never happened before.
if i do as @Gijs told me and set AlwaysPanParallelViews to YES RMB pans the view but de Cplan changes and matches World top.
Quite weird…
@John_Brock @Gijs anyway i think it seems easier to make a new scheme from scratch and maybe i found what happened!
thank you both for your help!
