Print command / Linetypes / match viewport definition bug
Hi, it seems that in the PRINT command, the option between “Match pattern definition” and “Match viewport display” doesn’t work. At Rhino 7 it works - the preview of linetype scale changed . Below is the same file:
Rhino 7 (different previews of linetypes scale) :
Rhino 8 (same previews of linetypes scale):
Hi!
I have the same issue in Rhino 8 on Mac. Is there any conclusion for that?
Thank you!
Today I have encountered the same issue. Can someone take a look into this matter? The option clearly doesnt change the line pattern.
I am using Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001
Hi Peter,
Please post SystemInfo and a small example file. Thanks!
Here is my System info and the example file:
Testfile-PrintOption-MatchPatternDefinition.3dm (55.4 KB)
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Commercial, build 2024-11-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 7-8-2024 (M-D-Y).
Primary OpenGL: NVIDIA RTX 2000 Ada Generation Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-25-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.12
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-25-2024
Driver Version: 32.0.15.5612
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
Hi @peter.zock and @Adam_Konicek,
This appears to be broken on Rhino 8.
RH-84881/Print-Match-pattern-definition-Not-Working
When the developer reviews it, it will likely be open for public view next week.
You will also be notified here where there is fix available in a Rhino service release.
Thanks for letting us know.
Sincerely,
Mary Ann Fugier
Hi all,
Just checking in on this.
I do all my 2d drafting in Rhino so this is a big issue for me as well.
Thanks
Hi Alex,
There is a new way for Rhino 8, that appears to be being used successfully.
The Rhino 8 way which is different than previous versions, is to make a Linetype definition and set it to use Model units See the discussion in this related tread here..
The linetype needs to be set to “use model units.” And the Print options do not do anything. They will likely be removed for this reason. The developers have the issue. I do not know if the Print option will stay and not work, or just be removed.
Give it a try and let us know if you still have issue.
You can email a file to tech@mcneel.com attn Mary if you need additional help.
Sincerely,
Mary Ann Fugier
Hi Mary,
Interesting, even though this linetypes box is meant to be universal, I noticed that it doesn’t affect my layout linetype display if I check this box while in model space. If I check the box while viewing the layout space, then it works.
Thanks!
Alex
Hi Alex,
Thank you for the feedback.
I will try it as you describe and see if I can repeat it.
Can I get your Rhino SystemInfo at your convenience?
In Rhino type SystemInfo command. Copy and paste the text results into your reply.
Sincerely,
Mary Ann Fugier
